New
I've written a custom manufacturing programming tool for ARM Cortex-M4 nRF52832 and nRF52810 devices. It uses a J-Link Plus USB programmer (J-Link V7.98g) and is implemented in Python using the Pylink package. The program configures J-Link to use SWD and connects to the target with chip_name 'nRF52832_xxAA' or 'nRF52810_xxAA', allowing the FICR device id and UICR information to be read.
I have a problem resetting the processor programmatically from Python. The Pylink reset() function does something, but does not trigger required Cortex M4 normal (0) reset sequence (wiki.segger.com/J-Link_Reset_Strategies#Type_0:_Normal) and (wiki.segger.com/J-Link_script_files#Reset_sequences). I've tried setting the reset strategy through Pylink and through J-Link command strings (wiki.segger.com/J-Link_Command_Strings). Strangely, if my program exits and disconnects from the J-Link DLL while the J-Link is still physically connected, the correct target processor reset is triggered.
I've seen that the J-Flash Start Application (F9) function performs a correct reset of the Cortex-M4 target processor, logging;
- Reset: Halt core after reset via DEMCR.VC_CORERESET.
- Reset: Reset device via AIRCR.SYSRESETREQ.
These messages match those in the SEGGER example CortexM reset script (wiki.segger.com/images/8/86/Ex…ortexM_Normal.JLinkScript).
The J-Link ARM DLL allows the reset behaviour to be customised by overriding the DLL ResetTarget() implementation with a script, but I have not been able to get this to work. It seems that should not be necessary if the J-Link DLL implements the normal Cortex M4 reset strategy.
I haven't tried exec()'ing J-Flash or J-Commander from within my program to achieve the correct reset. I understand this would require a second connection to J-Link DLL which is not supported.
Any help or advice on how to solve this would be appreciated.
