Renesas R7S721000 stand alone mode programming error
  • Renesas R7S721000 stand alone mode programming error
    Hello
    We have a problem with Renesas R7S721000 which is similar to this one: [SOVED] Unable to program in stand-alone mode - J-Link/Flasher related - SEGGER - Forum
    Flashing from PC works perfectly, but in stand alone mode it gives an error.
    I have updated the flasher FW to the latest version but it doesn't help.
    Here is my Jlink commander output:
    SEGGER J-Link Commander V7.96a (Compiled Mar 14 2024 17:15:38)
    DLL version V7.96a, compiled Mar 14 2024 17:14:50
    Firmware: J-Link / Flasher ARM V5-1 compiled Sep 11 2024 10:30:39
    Hardware version: V5.10
    J-Link uptime (since boot): 0d 00h 01m 23s
    S/N: 165105919
    License(s): JFlash, GDB
    USB speed mode: Full speed (12 MBit/s)
    IP-Addr: DHCP (no addr. received yet)
    VTref=3.292V
    J-Link>connect
    Please specify device / core. <Default>: R7S721000_DUALSPI
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>
    Device "R7S721000_DUALSPI" selected.
    Connecting to target via JTAG
    ConfigTargetSettings() start
    ConfigTargetSettings() end - Took 36us
    TotalIRLen = 4, IRPrint = 0x01
    JTAG chain detection found 1 devices:
    #0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
    DPv0 detected
    AP map detection skipped. Manually configured AP map found.
    AP[0]: AHB-AP (IDR: Not set)
    AP[1]: APB-AP (IDR: Not set)
    AP[2]: MEM-AP (IDR: Not set)
    Using preconfigured AP[1] as APB-AP
    AP[1]: APB-AP found
    ROMTbl[0][0]: CompAddr: 80002000 CID: B105900D, PID: 003BB906 CTI (?)
    ROMTbl[0][1]: CompAddr: 80008000 CID: B105900D, PID: 003BB906 CTI (?)
    ROMTbl[0][2]: CompAddr: 8000C000 CID: B105900D, PID: 003BB906 CTI (?)
    ROMTbl[0][3]: CompAddr: 8000F000 CID: B105F00D, PID: 000A3FA9 ???
    ROMTbl[0][4]: CompAddr: 80020000 CID: B105100D, PID: 000BB4A9 ROM Table
    ROMTbl[1][0]: CompAddr: 80021000 CID: B105900D, PID: 001BB961 TMC
    ROMTbl[1][1]: CompAddr: 80022000 CID: B105900D, PID: 003BB906 CTI (?)
    ROMTbl[1][2]: CompAddr: 80023000 CID: B105900D, PID: 004BB912 TPIU
    ROMTbl[1][3]: CompAddr: 80024000 CID: B105900D, PID: 001BB908 CSTF
    ROMTbl[1][4]: CompAddr: 80030000 CID: B105900D, PID: 000BBC09 Cortex-A9
    Found Cortex-A9 r3p0
    6 code breakpoints, 4 data breakpoints
    Debug architecture ARMv7.0
    Data endian: little
    Main ID register: 0x413FC090
    I-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
    D-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
    System control register:
    Instruction endian: little
    Level-1 instruction cache disabled
    Level-1 data cache disabled
    MMU disabled
    Branch prediction disabled
    Memory zones:
    Zone: "Default" Description: Default access mode
    Zone: "AHB-AP (AP0)" Description: DMA like acc. in AP0 addr. space
    Zone: "APB-AP (AP1)" Description: DMA like acc. in AP1 addr. space
    Cortex-A9 identified.
    And here is my serial port output:
    $BTL: Bootloader started successfully
    $BTL: Initializing file system... OK
    $BTL: Trying to open firmware file... ERR: File not found
    $BTL: Check for valid firmware... OK
    $BTL: Starting firmware...<CR><NUL>$FW: Initializing file system...
    $FW: Initializing NET module...
    $FW: Initializing FTP server...
    $FW: Initializing web server...
    $FW: Initializing telnet server...
    $FW: Initializing CMD module...
    $FW: Firmware started successfully
    #auto
    #ACK
    #STATUS:INITIALIZING
    #STATUS:CONNECTING
    #ERR255:Timeout while preparing target, core does not stop. (PC = 0xFFFF007C, CPSR = 0x600001DB, LR = 0x18000004)!
    Do you have any suggestions?
