[SOLVED] J-Link Base trying to update firmware
  • [SOLVED] J-Link Base trying to update firmware
    Hi there,
    We've observed that the J-Link Base connected to our setup occasionally tries to update its firmware, but fails since the setup is not connected to the internet. Is it possible to prevent the J-Link Base from attempting to check/perform updates?
    1. SEGGER J-Link Commander V7.96l (Compiled Jun 12 2024 18:56:19)
    2. DLL version V7.96l, compiled Jun 12 2024 18:55:26
    3. J-Link Command File read successfully.
    4. Processing script file...
    5. J-Link>USB ********
    6. Connecting to J-Link via USB...Updating firmware: J-Link V10 compiled Jan 30 2023 11:28:07
    7. Replacing firmware: J-Link V10 compiled Jun 3 2015 BTL
    8. Waiting for new firmware to boot
    9. FAILED: Communication timed out: Requested 4 bytes, received 0 bytes !
    10. Could not read J-Link capabilities.
    11. Cannot connect to J-Link
    12. J-Link>Exit
    13. Script processing completed.
    You can disable the automatic firmware updates with the DisableAutoUpdateFW command string.
    wiki.segger.com/J-Link_Command_Strings#DisableAutoUpdateFW
    Simon
