the gnu linker bug for new version of segger
    • the gnu linker bug for new version of segger
      dear:
      now i am use the segger studio of v7.3. the gnu linker is used for cortex-m33 but this is some error like "prinops.c:(.text.libc.vfprintf_l+0x5c): undefined reference to `__SEGGER_RTL_vfprintf'".
      and segger linker is ok。
      how to solver this problem for gnu linker ? :thumbup:
      Most likely the library I/O type is not correctly set in the project.
      Please take a look here for more information: https://wiki.segger.com/Embedded_Studio_Library_IO
      SebastianB
    • hi:
      thank your reply.
      you,re right. According to the documentation, SEGGER_RTT_printf can be used. But there,re two question。
      One problem is that the current SEGGER_RTT_printf formatting output has too many restrictions (such as outputting long long), and the application is not compatible with the previous one as below.
      * SEGGER_RTT_printf
      * Function description
      * Stores a formatted string in SEGGER RTT control block.
      * This data is read by the host.
      * Parameters
      * BufferIndex Index of "Up"-buffer to be used. (e.g. 0 for "Terminal")
      * sFormat Pointer to format string, followed by the arguments for conversion
      * Return values
      * >= 0: Number of bytes which have been stored in the "Up"-buffer.
      * < 0: Error
      * Notes
      * (1) Conversion specifications have following syntax:
      * %[flags][FieldWidth][.Precision]ConversionSpecifier
      * (2) Supported flags:
      * -: Left justify within the field width
      * +: Always print sign extension for signed conversions
      * 0: Pad with 0 instead of spaces. Ignored when using '-'-flag or precision
      * Supported conversion specifiers:
      * c: Print the argument as one char
      * d: Print the argument as a signed integer
      * u: Print the argument as an unsigned integer
      * x: Print the argument as an hexadecimal integer
      * s: Print the string pointed to by the argument
      * p: Print the argument as an 8-digit hexadecimal integer. (Argument shall be a pointer to void.)
      The second problem is that there is no sprinf function?
    • New
      Did you setup the project correctly for long long printing support? (Code > Printf/Scanf > Printf Integer Support set to "Long Long")
      "sprintf" does of course exist and may simply be used after including "stdio.h".
      Could you check whether the application was prepared correctly?
      SebastianB
