[SOLVED] Issue when connecting to chain with multiple TAPs
  • [SOLVED] Issue when connecting to chain with multiple TAPs
    I have sent this as a support ticket but had no response since May 15, I will post it here again.
    we are trying to use the jlink debugger to debug our custom SoC.
    Our JTAG chain contains 2 taps: each one connected to a separate Risc-V processor. We are facing a problem where jlinkGDBServer isn't able to detect the 2 CPU TAPs (openocd connects successfully)
    The JTAG chain looks as follows: TDI -> TAP1(RV32) -> TAP0(RV32) -> TDO. Both taps have an IR length of 5.
    we run the following jlink command, trying to connect to tap 0:
    >>> JLinkGDBServer -device rv32 -speed auto -vd -jlinkscriptfile script.JLinkScript
    with the script file 'script.JlinkScript' containing the following:
    void ConfigTargetSettings(void) {
    // connect to TAP0
    JTAG_IRPre = 0; // Sum of IRLen of all JTAG TAPs preceding the one we want to communicate ith
    JTAG_DRPre = 0; // Number of JTAG TAPs preceding the one we want to communicate with
    JTAG_IRPost = 5; // Sum of IRLen of all JTAG TAPs following the one we want to communicate with
    JTAG_DRPost = 1; // Number of JTAG TAPs following the one we want to communicate with
    JTAG_IRLen = 5; // IRLen of device we want to communicate with
    JTAG_AllowTAPReset = 1;
    JTAG_SetDeviceId(0, 0x10004c6f);
    JTAG_SetDeviceId(1, 0x10003c6f);
    return 0;
    We get this output:
    ERROR: CPU-TAP not found in JTAG chain
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    we even tried the following, specifying the offset of tap 0 inside the chain:
    >>> JLinkGDBServer -device rv32 speed auto -vd -jtagconf 0,0
    but to no avail.
    However, if we run JlinkExe, type connect and run through the whole menu, we get this:
    TotalIRLen = 10, IRPrint = 0x00A5
    JTAG chain detection found 2 devices:
    #0 Id: 0x10004C6F, IRLen: ?, Unknown device
    #1 Id: 0x10003C6F, IRLen: ?, Unknown device
    ****** Error: CPU-TAP not found in JTAG chain
    Error occurred: Could not connect to the target device.
    For troubleshooting steps visit: wiki.segger.com/J-Link_Troubleshooting
    The same happens when we also specify JtagConf 0,0 inside the menu.
    Is there a way we can know in more detail what is failing so we can debug on the hardware side ?
    NOTE: if we connect either CPUs directly to JLINK there are no problems, the problem is only when daisy chaining them.
    NOTE 2: if we change the IDCODE to have the manufacturer ID of another RISC-V company like sifive, the device connects and identifies the TAPs, but doesn't with our manufacturer ID
