[SOLVED] TLE9893-2QKW62S SystemView high frequency event tracking
  • [SOLVED] TLE9893-2QKW62S SystemView high frequency event tracking
    Hello Team,
    Setup Details
    Controller : TLE9893-2QKW62S
    Tool: SEGGER SystemView
    Debugger : Segger JLink Ultra+
    Tool Versions
    SEGGER SystemView : V3.52a
    Configurations
    Controller Freq : 60 MHz
    Interface Speed : Tried with multile speed values (4 MHz to 50 MHz) in Recorder configuration.
    Tracked events details
    ISR_A: 50 micro sec frequency
    ISR_B: 100 micro sec frequency
    ISR_C: 1 milli sec frequency
    ISR_SYSTICK : 1 milli sec frequency
    Task_A: 1 milli sec frequency
    Task_B: 10 milli sec frequency
    Code Reference
    We integrated same code present in the downloaded tool's src folder.
    We are facing sporadic issues and not able to do tracking as needed.
    Below are some of our observations:
    When tracking only Task_A, Task_B and SYSTICK:
    Everything is working fine no issues observed.
    When tracking Task_A, Task_B and ISR_B:
    Sporadic issues observed like:
    - Unwanted ISRs and Tasks showing in the systemview timeline
    - Overflow event warnings
    - Error detection warnings
    We tried below sizes expecting to solve the issue but it did not work:
    - SEGGER_SYSVIEW_RTT_BUFFER_SIZE --> set to 2048, 4096, 8192
    Could you please support us below open Points
    - Why peak throughput not reaching Segger JLink Ultra+ supported frequency? Download speed up to 4 MB/s
    - What does this Error -140 mean in Log window and what could be reason for it?
    - Is system view capable of tracking events that occur at 50 micro second frequency? what is min frequency of events that sytemview can handle and how long?
  • Hello Vinay,
    I have replied to your support ticket.
    The issue was caused by the configuration of the interrupt locking fuction (SEGGER_RTT_LOCK).
    In future, please use only use one support channel for one topic.
    We will consider this case as closed now.
    Tobias
