I have made my own example-project for a microcontroller STR911FA with the embOS. I have used start project Start_STR912.eww (IAR 5.11) as a template. Now I wanted to change a position of this project and build it and run somewhere else. I see that start project is connected somehow with a files in folder GenOSSrc. These files are not included in Start_STR912 IAR Workspace and in the configuration window of this project also and I see no connection with the folder. How are they included in the project ? Second question is, where can I find(files) a C-code with the stack pointer initialization for each ARM mode, FLASH/RAM initialization, exception and IRQ vectors initialization(usuually located at the beginning of FLASH ROM)? In standard ST projects this is placed in file 91x_init.s and 91x_vect.s. If I wanted to change something, I need these files.
New location for embOS project and memory initialization
Share
