Using RA8876 Display with emWin
    • Using RA8876 Display with emWin
      Greetings.
      I am planning to use the RA8876 display with a NXP MK56 series MCU based custom board. Is it possible to use emWin for developing the GUI for the RA8876 display? I see no driver supports this controller so I was thinking about using GUIDRV_Lin driver. Will that work? Also how does emWin send data to the display as there are no GUI_PORT_API functions for the Linear driver?
      Any help in the right direction will be appreciated.
      Thanks.
      It is not possible to use the RA8876 directly with emWin. You would need another controller which generates the proper signals for the RA8876.
      Typically a display controller build in to the MCU is used to generate these signals.
      In this case you would utilize the GUIDRV_Lin driver to manage the framebuffer on MCU side. The internal display controller will parse the framebuffer and generate the signals for the RA8876.
