Reset Behavior with J-Link Ultra+ on MSPM0G3507 Microcontroller
  • Reset Behavior with J-Link Ultra+ on MSPM0G3507 Microcontroller
    I use the MSPM0G3507 microcontroller and J-Link Ultra+, the latest version (V7.94b) of the J-Link firmware and software.
    There are differences between XDS110 and J-Link reset handling.
    I have a test code that waits for 5 seconds and goes to SHUTDOWN mode.
    First Issue,
    When I download the hex file with the XDS110 debugger, according to my choice "Debug CPU" or "Debug SW" reset triggers, code running without any problem.
    But, if I download the same hex file with Segger J-Link Ultra+ , it wakes up from SHUTDOWN mode. But, If I manage to wake up with a different reset (like holding1 second of the reset pin), it wakes up POR reset and works without any problem.
    Second Issue, I tried to run theRSetType 2 functionality in J-Link Commander. However, when I enable RSetType 2and attempt to reset the device using the commander tool, the reset line does not toggle. A CPU behaves as if it is in a reset state and not running.
    I have attached an image showing the output from the commander tool and the SWD signals captured by a logic analyzer under RSetType 2 testing.
    Questions
    1. Which type of resets can be applied via J-Link Ultra+ to MSPM0G3507?
    2. Why RSetType 2 not trigger SWD reset pin?
    Thank you in advance for your answers and interest.
    The post was edited 1 time, last by ahenk ().
