[ABANDONED] SES RTOS Awareness thread work not right
  • [ABANDONED] SES RTOS Awareness thread work not right
    SES RTOS Awareness thread not right
    I use Ozone coulud show 47 task
    but SES could only show 27 task and i also set the limit from 25 to 64 and enable RTOS Awareness with FreeRTOS CortexM7
    I think it's a bug.
    It seems though that ES is shipping with older variants of the RTOS awareness scripts.
    Could you try to load the Ozone RTOS awareness script in ES?
    Does it work better now?
    open with Ozone or SES ,the default script always M4 not M7, all config is M7 that i checked
    i have check the jdebug file , the file write it "M4"
    you could create a new STM32H7 project in SES or Ozone, it will show the same M4 script result and the SES bug could be reproduced
    Not sure I understand.
    Did you now try the M7 Ozone script in ES or not? Does it work better or not?
    ES will not set the script automatically. So if you have selected the wrong M4 script that is user error. You have to select the M7 script of course if you are using a Cortex-M7.
