[SOLVED] Hardfault Error While Debugging in Systemview
  • [SOLVED] Hardfault Error While Debugging in Systemview
    The SystemView is running properly when I don't integrate TouchGFX into STM32CubeIDE. However, when I integrate TouchGFX into my code, I'm able to debug with ST-Link. On the other hand, when I use J-Link, I'm getting a hardfault error while debugging. Below, I have attached screenshot .
    The screenshots do not show SystemView running. Are you sure you are in the right subforum?
    ST-Link is also not compatible to SystemView, so not sure why you compare these.
    Could you clarify what you are doing and what is working and what not? From your OP this is not clear.
