Hi!
Since v7.88l JLINK.EXE refuses to run my scripts properly (with jlink plus connected):
Skript1 - last command "connect" not executed:
device R7FA2E1A9
si SWD
speed 4000
connect
After further investigation I suppose that only the first line is executed properly, if device, speed and interface is given already as command line parameter before that.
Skript2:
erase 0x40100000, 0x40100FFF, reset
erase 0x40100000, 0x401000FF, reset
loadfile testfile.hex
results in:
As you can see after "Processing script file...", there is something wrong.
I tested all versions x86_x64 since v7.86f till v7.92d.
Can anyone confirm that behaviour? Did I miss something in the release notes?
Perhaps it has something to do with
7.88l:
Other changes:
Commander
If a C/C++ comment was used in a command that accepts parameters, the comment was accidentally interpreted as parameter. Fixed.
HaJo
device R7FA2E1A9
si SWD
speed 4000
connect
- "C:\Program Files\SEGGER\JLink\jlink.exe" -device R7FA2E1A9 -CommanderScript RA2E1_connect_flash_test.jlink
- SEGGER J-Link Commander V7.92d (Compiled Sep 8 2023 09:56:39)
- DLL version V7.92d, compiled Sep 8 2023 09:55:04
- J-Link Command File read successfully.
- Processing script file...
- connect000ice R7FA2E1A9
- J-Link connection not established yet but required for command.
- Connecting to J-Link via USB...O.K.
- Firmware: J-Link V10 compiled Jan 30 2023 11:28:07
- Hardware version: V10.10
- J-Link uptime (since boot): N/A (Not supported by this model)
- S/N: 600111968
- License(s): RDI, FlashBP, FlashDL, JFlash, GDB
- VTref=3.248V
- Script processing completed.
- Type "connect" to establish a target connection, '?' for help
Skript2:
results in:
- "C:\Program Files\SEGGER\JLink\jlink.exe" -device R7FA2E1A9 -if SWD -speed auto -CommanderScript RA2E1_connect_flash_test.jlink
- loadfile testfile.hex01000FF, reset, reset
- S/N: 600111969
- VTref=3.241V
- Target connection not established yet but required for command.
- Device "R7FA2E1A9" selected.
- Connecting to target via SWD
- InitTarget() start
- Identifying target device...
- SWD selected. Executing JTAG -> SWD switching sequence...
- Initializing DAP...
- DAP initialized successfully.
- InitTarget() end - Took 20.8ms
- Found SW-DP with ID 0x5BA02477
- DPIDR: 0x5BA02477
- CoreSight SoC-400 or earlier
- Scanning AP map to find all available APs
- AP[2]: Stopped AP scan as end of AP map has been reached
- AP[0]: AHB-AP (IDR: 0x74770001)
- AP[1]: APB-AP (IDR: 0x44770002)
- Iterating through AP map to find AHB-AP to use
- AP[0]: Core found
- AP[0]: AHB-AP ROM base: 0x4001A000
- CPUID register: 0x411CD200. Implementer code: 0x41 (ARM)
- Feature set: Baseline
- Cache: No cache
- Found Cortex-M23 r1p0, Little endian.
- Cortex-M (ARMv8-M and later): The connected J-Link (S/N 600111969) uses an old firmware module that does not handle I/D-cache corr
- ectly. Proper debugging functionality cannot be guaranteed if cache is enabled
- FPUnit: 4 code (BP) slots and 0 literal slots
- Security extension: not implemented
- CoreSight components:
- ROMTbl[0] @ 4001A000
- [0][0]: E000E000 CID B105900D PID 000BBD20 DEVARCH 47702A04 DEVTYPE 00 Cortex-M23
- [0][1]: E0001000 CID B105900D PID 000BBD20 DEVARCH 47701A02 DEVTYPE 00 DWT
- [0][2]: E0002000 CID B105900D PID 000BBD20 DEVARCH 47701A03 DEVTYPE 00 FPB
- [0][3]: 40019000 CID B105900D PID 000BBD20 DEVARCH 47710A31 DEVTYPE 31 MTB
- Memory zones:
- Zone: "Default" Description: Default access mode
- Cortex-M23 identified.
- 'erase': Performing implicit reset & halt of MCU.
- Reset: Halt core after reset via DEMCR.VC_CORERESET.
- Reset: Reset device via AIRCR.SYSRESETREQ.
- Erasing selected range...
- CPU is running at low speed (8000 kHz).
- J-Link: Flash download: Total time needed: 0.233s (Prepare: 0.151s, Compare: 0.000s, Erase: 0.052s, Program: 0.000s, Verify: 0.000
- s, Restore: 0.029s)
- Flash sectors within Range [0x40100000 - 0x40100FFF] deleted.
- Erasing done.
7.88l:
Other changes:
Commander
HaJo
