[SOLVED] Error: Specified flashloader exceeds max. size of 64 KB.
  • [SOLVED] Error: Specified flashloader exceeds max. size of 64 KB.
    USB speed mode: High speed (480 MBit/s)
    VTref=3.375V
    Target connection not established yet but required for command.
    ****** Error: Specified flashloader exceeds max. size of 64 KB.
    No valid device has been selected.
    J-Link>h
    Please specify device / core. <Default>: embed32
    Type '?' for selection dialog
    Device>
    hello, guys
    I always encounter this error when try to make a open flashloader work, so
    1. what is the cause of this error?
    2. can I increase this size limit value, such as 128KB?
    3. Specifically, which section's size is out of bounds in the ELF file?
    The post was edited 1 time, last by lyric ().
  • The size limit cannot be increased by you and > 64 KB sounds insane for a flash algorithm…
    You may post your ELF file here or send it via PM, if you want us to have a look.
