We use J-Links connected via USB to a Raspberry Pi 4. From time to time it is not more reacting.
When logging into the Raspberry Pi 4 which controls the J-Link and calling lsusb, I don't see the J-Link anymore.
E.g. it look like this:
xxx:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
xxx:~ $
When doing a reboot of the Raspberry Pi 4, the J-Link is still not findable.
I assume it is not answering anymore via USB.
Unfortunately not reproduceable, perhaps when not using it for a long time, I don't know.
We already exchanged cable in the past, but has not helped, occured again.
Because the testrack it on a remote location, which is difficult to reach, two question came up:
- Can I somehow reset the J-Link? Perhaps with removing power from Raspberry Pi 4 side? I already searched the Internet, found hub-ctrl and uhubctl to switch off power of USB port, in the hope it then recovers,
but at least I was not successful this time.
- The other question would be how to prevent such a situation in future.
I told my collegue to replug J-Link (he will do in a few minutes), then I assume it can be found again via lsusb.
Pay attention: The device and serial number of the device in the testrack is different than the local one I am using.
When I can connect again to the J-Link in the testrack, I can deliver the exact info of this device.
Many thanks for your help!
This is debug output of a reboot, filter with word "usb":
xxx:~ $ dmesg | grep usb
[ 0.179807] usbcore: registered new interface driver usbfs
[ 0.179885] usbcore: registered new interface driver hub
[ 0.179972] usbcore: registered new device driver usb
[ 0.180490] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 1.394097] usbcore: registered new interface driver r8152
[ 1.394205] usbcore: registered new interface driver lan78xx
[ 1.394302] usbcore: registered new interface driver smsc95xx
[ 1.449465] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.449512] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.449551] usb usb1: Product: xHCI Host Controller
[ 1.449582] usb usb1: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
[ 1.449614] usb usb1: SerialNumber: 0000:01:00.0
[ 1.451756] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.451800] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.451838] usb usb2: Product: xHCI Host Controller
[ 1.451868] usb usb2: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
[ 1.451899] usb usb2: SerialNumber: 0000:01:00.0
[ 1.455468] usbcore: registered new interface driver uas
[ 1.455612] usbcore: registered new interface driver usb-storage
[ 1.466564] usbcore: registered new interface driver usbhid
[ 1.466596] usbhid: USB HID core driver
[ 1.732725] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.915393] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.915455] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.915492] usb 1-1: Product: USB2.0 Hub
[ 3.053289] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3.973665] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3.974389] usb 1-1-port3: attempt power cycle
[ 5.233370] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 5.989802] usbcore: registered new interface driver brcmfmac
[ 6.182377] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 6.183919] usb 1-1-port3: unable to enumerate USB device
[ 1794.959048] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1795.869039] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1795.869758] usb 1-1-port3: attempt power cycle
[ 1797.129087] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1798.039069] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1798.039837] usb 1-1-port3: unable to enumerate USB device
xxx:~ $ lsusb
xxx:~ $
