Creating a memory device with a dialog
    • Creating a memory device with a dialog
      Hello to everyone,
      I need to create a memory device with a content of a dialog window.
      There was an old thread https://forum.segger.com/index.php/Thread/8148-get-data-pointer-in-window/ and undocumented function GUI_MEMDEV_CreateWindowDevice() was mentioned there.
      When I use that function I get a memory device with a content of a parent window.
      But how to get a memory device with a content of a whole dialog with all child widgets?
      Of course we can use WM_ForEachDesc() with GUI_MEMDEV_CreateWindowDevice() for all descendants and "collect" such a content in a one device.
      But maybe there is a more simple way to do this.
      Thanks.
      Anthony
      Unfortunately, there is no dedicated API function to copy an entire dialog into a memory device.
      But, you can create a memory device with the same size as the dialog at the same position and copy the LCD content into the memory device.
      This might look like this:
      1. xPos = WM_GetWindowOrgX (pMsg->hWin);
      2. yPos = WM_GetWindowOrgY (pMsg->hWin);
      3. xSize = WM_GetWindowSizeX(pMsg->hWin);
      4. ySize = WM_GetWindowSizeY(pMsg->hWin);
      5. hMem = GUI_MEMDEV_Create(xPos, yPos, xSize, ySize);
      6. GUI_MEMDEV_CopyFromLCD(hMem);
      Attached is an example doing this.
      • MainTask.zip
        (1.28 kB, downloaded 1,086 times, last: )
    • Hello, Sven,
      thanks for your sample, works fine, but unfortunately it is not quite suitable for me. I need to create a device from a dialog that should not be visible on the screen. In addition a dialog can contain transparency so background should not count in that case.
      I attached my sample with a simple code scenario that collects all hidden dialog pixel data into a one device. Works fine except for one thing: after the dialog is shown when clicking on a child widget others widgets become hidden. I think it might be about some incomplete actions (maybe GUI context lost etc...). Maybe you can tell how to do this "icing on the cake".
      Thank you.
      • Main.zip
        (1.45 kB, downloaded 839 times, last: )
      Anthony
      The post was edited 1 time, last by cilmagemlu ().
      for those who are interested: the problem is solved by calling
      GUI_MEMDEV_FadeInWindow(WM_HBKWIN, 0);
      after the dialog is shown.
      In this case the main job of this function has no meaning but somehow it sets things right.
      Can't explain furhter as I use STemWin and don't have source files to better understanding.
      Anthony
