I can change the module number assignments on the Flasher Hub web interface at Configuration > Flasher Modules. Equivalent functionality is supposed to be available through the telnet interface with the #ASSIGNMODULE command. However this command only returns #NACK. Flasher Hub firmware version is 1.14, which is the latest.
[SOLVED] flasher hub ASSIGNMODULE command does not work (v 1.14)
Share
