[SOLVED] Using RTT in background mode with TI RM46
  • [SOLVED] Using RTT in background mode with TI RM46
    I'm using Segger RTT with A TI Hercules RM46L (ARM® Cortex®-R4F 32-Bit RISC CPU), and I want to use RTT in background mode.
    My problem is that the AP map detection seems to fail and fall back to the "Stop mode".
    imgur.com/a/7BwTDBY
    Imgur link because the forum is complaining about message size
    While the SEGGER wiki does not mention it supports the cortex-R core, the Using RTT on Cortex-A/R based devices application notes mention that it can be enabled if the AHB-AP exist
    imgur.com/a/RKgmcW6
    In the rm46l852 datasheet, there's mention that the AHB-AP exist
    imgur.com/a/KrjfgOD
    So according to this information, I think it should be feasible to enable it.
    It must be a configuration problem.
    How do I enable the RTT in background mode?
    I have tried to add the JlinkScritp without success
    1. int ConfigTargetSettings(void) {
    2. JLINK_SYS_Report("J-Link Script: ConfigTargetSettings(): Skip ECC RAM initialization");
    3. JLINK_ExecCommand("SetSkipInitECCRAMOnConnect = 1");
    4. JLINK_ExecCommand("SetIndexAHBAPToUse = 0");
    5. return 0;
    6. }
    As an additional note, I think I'm having a similar problem to this unresolved thread from 2019:
    [ABANDONED] TI RM57x (Cortex R5F) and RTT Background Mode
    Best,
    Gabriel
  • Hi Gabriel,
    RTT is already executed in background mode on the RM4x devices.
    The background AP is implemented natively, so no actions/script files on your side needed.
    You can verify this by opening the RTT tab in the J-Link Web Control Panel:
    wiki.segger.com/J-Link_-_Web_control_panel
    Only normal memory reads (e.g. via Mem32 in the J-Link Commander) will use stop mode,
    as background access mode is currently only used by RTT & HSS.
    I also answered you in the support ticket case.
