[SOLVED] Can I use RTT and SystemView API at the same time?
  • [SOLVED] Can I use RTT and SystemView API at the same time?
    I'm trying to use RTT Viewer for logging and SystemView for tracing at the same time.
    Is it possible?
    If so, what are the steps to make sure they integrate properly with each other?
    Can I simply do:
    1. SEGGER_RTT_Init();
    2. SEGGER_RTT_printf(0, "RTT online!");
    3. SEGGER_SYSVIEW_Conf();
    4. SEGGER_SYSVIEW_Print("SystemView online!");
    Gabriel
  • Hello Gabriel,
    Yes you can do that.
    Per default SystemView uses channel/buffer 1 for communication and RTT Viewer per default scans channel/buffer 0.
    Just make sure not to use the same channel for both.
