Flashloader of each OS
    • Flashloader of each OS
      Suppose that the flashloader is for all OS as Windows/Linux/MacOS, does it?
      I got strange result when loadbin for specific address with my flashloader on MacOS but it works well on Linux and Windows with JLinkExe of v7.82a
      I found from log, the sectors was analyzed differently for the same bin file and the same address to program.
      Operating on Linux:
      1. Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink_V782a/JLinkGUIServerExe
      2. T8672F740 005:137.204 Forking J-Link GUI Server: /opt/SEGGER/JLink_V782a/JLinkGUIServerExe
      3. T8672F740 005:464.821 Failed to connect to J-Link GUI Server.
      4. T8672F740 005:464.898 -- CPU speed could not be measured.
      5. T8672F740 005:464.960 -- Start of comparing flash
      6. T8672F740 005:464.986 -- Flash algorithm supports a native verify function which is used to compare the flash content.
      7. T8672F740 005:465.013 -- Comparing range 0x10038000 - 0x1003FFFF (8 Sectors, 32 KB), using verify function of the RAMCode
      8. T8672F740 005:465.041 -- Recalculating RAMUsage for optimal performance during programming
      9. T8672F740 005:465.073 --
      10. T8672F740 005:465.092 -- Recalculating RAMUsage for optimal performance during programming
      11. T8672F740 005:465.116 --
      12. T8672F740 005:477.577 -- Data does not match for sectors 56-63
      13. T8672F740 005:477.660 -- End of comparing flash
      14. T8672F740 005:477.691 -- Start of erasing sectors
      15. T8672F740 005:477.722 -- Erasing range 0x10038000 - 0x1003FFFF ( 8 Sectors, 32 KB)
      16. T8672F740 005:477.750 -- Recalculating RAMUsage for optimal performance during programming
      17. T8672F740 005:477.776 --
      18. T8672F740 005:477.795 -- Initializing RAMCode (InitType: 1 = Erase)
      19. T8672F740 005:477.821 --
      20. T8672F740 005:477.870 -- Executing UnInit()
      21. T8672F740 005:477.896 --
      22. T8672F740 005:480.769 -- Executing Init(1)
      23. T8672F740 005:480.823 --
      24. T8672F740 005:835.376 -- End of erasing sectors
      25. T8672F740 005:835.429 -- Start of flash programming
      26. T8672F740 005:835.451 -- Programming range 0x10038000 - 0x1003FFFF ( 8 Sectors, 32 KB)
      27. T8672F740 005:835.472 -- Recalculating RAMUsage for optimal performance during programming
      28. T8672F740 005:835.483 --
      29. T8672F740 005:835.507 -- Initializing RAMCode (InitType: 2 = Program)
      30. T8672F740 005:835.525 --
      31. T8672F740 005:835.539 -- Executing UnInit()
      Operating on MacOS:
      Brainfuck Source Code
      1. T14132C0 001:702.373 Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V780/JLinkGUIServerExe
      2. T14132C0 001:702.507 Forking J-Link GUI Server: /Applications/SEGGER/JLink_V780/JLinkGUIServerExe
      3. T14132C0 001:706.161 J-Link GUI Server info: "J-Link GUI server V7.82a "
      4. T14132C0 001:711.535 -- CPU speed could not be measured.
      5. T14132C0 001:711.574 -- Start of comparing flash
      6. T14132C0 001:711.597 -- Flash algorithm supports a native verify function which is used to compare the flash content.
      7. T14132C0 001:762.182 -- Comparing range 0x10038000 - 0x10038FFF (1 Sector, 4 KB), using verify function of the RAMCode
      8. T14132C0 001:762.220 -- Recalculating RAMUsage for optimal performance during programming
      9. T14132C0 001:762.230 --
      10. T14132C0 001:762.237 -- Recalculating RAMUsage for optimal performance during programming
      11. T14132C0 001:762.246 --
      12. T14132C0 001:914.218 -- Data does not match for sector 56
      13. T14132C0 001:914.283 -- End of comparing flash
      14. T14132C0 001:914.304 -- Start of erasing sectors
      15. T14132C0 001:914.325 -- Erasing range 0x10038000 - 0x10038FFF ( 1 Sector, 4 KB)
      16. T14132C0 001:914.342 -- Recalculating RAMUsage for optimal performance during programming
      17. T14132C0 001:914.357 --
      18. T14132C0 001:983.192 -- End of erasing sectors
      19. T14132C0 001:983.212 -- Start of flash programming
      20. T14132C0 001:983.224 -- Programming range 0x10038000 - 0x10038FFF ( 1 Sector, 4 KB)
      21. T14132C0 001:985.594 -- Recalculating RAMUsage for optimal performance during programming
      22. T14132C0 001:985.609 --
      23. T14132C0 001:985.617 -- Program page timeout too high. Use default timeout: 10000 [s]
      24. T14132C0 001:985.628 --
      25. T14132C0 012:760.814
      26. ***** Error:
      27. T14132C0 012:760.997
      28. PC of target system has unexpected value after programming sector. (PC = 0x00000000)!
      29. ---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
      30. PC = 00000000
      31. Current: R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
      32. R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
      33. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------
      34. T14132C0 012:773.215
      35. ***** Error:
      36. T14132C0 012:773.348 Programming failed (error code = -1) for block @ address 0x10038000 (207479589)
      37. T14132C0 012:773.399 -- End of flash programming
      38. T14132C0 012:773.464 -- Start of restoring
      39. T14132C0 012:773.508 -- End of restoring
      40. T14132C0 012:785.750 Restarting due to program error (possibly skipped erasure of half-way erased sector).
    • If switch the loadbin procedure to loadbin another file and it works.
      If change the loadbin address to exclue the baseaddress and it works.
      if updated the bin file with padding and it works.
      Is it reasonable for these tree operations?
      Thanks.
    • Without a complete J-Link log file for both cases:
      • good (e.g. Windows/Linux)
      • bad (macOS)
      it is not possible to help here further.
      The log file would give more insight if you are actually working with identical settings or you just think you are.
      I assume that you have written your own flash loader.
      Are you 100% sure that you are using the same version of the flash loader on the good and bad platforms?
      Just to make sure that your macOS setup is not using an old version of your flash loader where some of your latest changes where not implemented yet.
