[SOLVED] RTT control block missing
  • [SOLVED] RTT control block missing
    I have integrated Systemview on my target with ARM9 CPU SAM9x60. As this is ARM9 it does not support RTT and hence I am trying for singleshot. My interface to board is Jlink. When I start SystemView on my PC and select Target->Start Recording, it shows be messages as in attachment1.
    When I click on OK, the other message Recorder starting remains for some time and green progress runs quickly and message box closes. After that I select Target->Read Recorded Data and it gives me message1 as in attachment 2.
    Click on OK and all windows remains blank. Can anyone please suggest what is wrong here?
    Pradeep
    in case your target does not support RTT, you need to save the data recording from the target to a file on the host system.
    This is explained in the manual here: segger.com/doc/UM08027_SystemView.html#Single_shot_recording
    In short, following steps are required:
    - Halt the application with the debugger when either the recording is done or the buffer is full
    - Get the RTT buffer address and number of bytes used (usually _SEGGER_RTT.aUp[1].pBuffer and _SEGGER_RTT.aUp[1].WrOff)
    - Save the used bytes from the buffer to a *.SVDat or *.bin file
    - Open the file in Ozone using File -> Load Data
    Sebastian
