[ABANDONED] stdint.h incorrect sizes
  • [ABANDONED] stdint.h incorrect sizes
    I am trying to convert an old NRF52840 project that works with 5.70a to work with the lastest build of 7.12a.
    However, it seems like the <stdint.h> is defining the integer sizes incorrectly.
    This code:
    1. sprintf(pinstr, "%u", currPin);
    Gives this warning:
    1. format '%u' expects argument of type 'unsigned int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
    This is a 32-bit processor. An unsigned int should be equal to an uint32_t correct? It seems like an "uint32_t" is defined as a long unsigned int
    ======= Adding Tests Size Info ===========
    1. sprintf(intbuf, "size of int is %d\r\n", sizeof(int));
    2. printf(intbuf);
    3. sprintf(intbuf, "size of unsigned int is %d\r\n", sizeof(unsigned int));
    4. printf(intbuf);
    5. sprintf(intbuf, "size of uint32_t is %d\r\n", sizeof(uint32_t));
    6. printf(intbuf);
    7. sprintf(intbuf, "size of int32_t is %d\r\n", sizeof(int32_t));
    8. printf(intbuf);
    1. size of int is 4
    2. size of unsigned int is 4
    3. size of uint32_t is 4
    4. size of int32_t is 4
    The post was edited 3 times, last by lcorbin ().
    Unfortunately it is not that simple.
    This is a problem that comes up with the Arm AEABI and with C++ mangled names ("exactly what is a uint32_t?"). '%u' should not be used for a uint32_t, you should use PRIuLEAST32 or PRIdLEAST32 from <inttypes.h>.
    Arm confuses the issue with the AEABI defining that 32-bit data are "unsigned" and "int".
    The C RTABI document and the AAPCS document do not discuss uint32_t, and nor does the C++ RTABI which, is more important here.
    The way to handle this is either cast uint32_t to unsigned (which would be incorrect for 16-bit systems),
    or to construct the print correctly for all systems: printf("%" PRIuLEAST32"\n", i);
    The reason why it worked in older versions has been that we defined uint32_t as unsigned int.
    Since V7.12 we use the type that the compiler defines for it (__UINT32_TYPE__), which for gcc happens to be long unsigned int.
    (clang and the SEGGER Compiler define this as unsigned int. There it would work.)
