We use the Nordic nRF52 devkit (52832) for our purpose. However it identifies itself (often, not always) after power on as:
Bus 001 Device 004: ID 1366:0101 SEGGER J-Link PLUS
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1366 SEGGER
idProduct 0x0101 J-Link PLUS
bcdDevice 1.00
iManufacturer 1 SEGGER
iProduct 2 J-Link
iSerial 3 000682979319
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0020
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 4
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 5
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
However after using the slide switch to power off/on the board it comes online on USB as
Bus 001 Device 005: ID 1366:0105 SEGGER J-Link
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idProduct 0x0105
bcdDevice 1.00
iProduct 2 J-Link
bLength 9
bDescriptorType 2
wTotalLength 0x0062
bNumInterfaces 3
iConfiguration 4
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 0
iFunction 5
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 5
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x03
call management
use DataInterface
bDataInterface 1
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 6
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
iInterface 7
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval
This is the operation mode we need. The fact that it presents itself as 2 very different SEGGER devices is very anoying.
I checked with JLinkConfig, the SEGGER driver is the latest available.
As this is on Linux, it would be nice if usb_modeswitch could be used here. I don't know the proper arguments for it.
best regards
Kees
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
bcdDevice 1.00
iProduct 2 J-Link
bLength 9
bDescriptorType 2
wTotalLength 0x0020
bNumInterfaces 1
iConfiguration 4
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 5
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
idProduct 0x0105
bcdDevice 1.00
iProduct 2 J-Link
bLength 9
bDescriptorType 2
wTotalLength 0x0062
bNumInterfaces 3
iConfiguration 4
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionProtocol 0
iFunction 5
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 5
CDC Header:
bcdCDC 1.10
bmCapabilities 0x03
call management
use DataInterface
bDataInterface 1
CDC ACM:
bmCapabilities 0x06
sends break
CDC Union:
bMasterInterface 0
bSlaveInterface 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 6
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
iInterface 7
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval
best regards
Kees
