[ABANDONED] "Error while recording. Recorder Stopped."
  • [ABANDONED] "Error while recording. Recorder Stopped."
    I've been trying to use Segger SystemView v3.32 PRO Licensed to troubleshoot a firmware bug that occurs randomly. This requires SystemView to record continuously for a long period of time. After I started recording for about 4-5 minutes, I got the error message "Error while recording. Recorder stopped". See screenshot below. After getting that error message, if I hit the "Start Recording" button again, recording would start again normally and I would receive the same error message after 4-5 minutes. So the firmware did not crash but something caused SystemView to stop recording and I do not know why. If the firmware crashed, the watchdog would kick in and reset the MCU. If the MCU got reset, I would get messages via my UART debug port during the boot-up process. So it has to be SystemView that caused the recording to stop. Please help!
    BTW, I also included a screenshot of the "System" window showing info and statistics when I got the error message "Error while recording. Recorder Stopped".
    The post was edited 4 times, last by py123 ().
    It appears that either SystemView is receiving an incorrect package or the debug interface is being disabled by your application.
    Are you using any low power/sleep modes?
    Could you try the latest SystemView version V3.50a and update the SystemView target sources accordingly in your project?
    If it still shows this issue could you provide a J-Link log file of the failing session?
    You can enable it in the SystemView recorder settings.
    Does your application work standalone without a J-Link connected? Or does it crash then as well?
    If you have a SystemView license that is in valid support period feel free to open a support ticket via our support channel as described in my signature.
