[SOLVED] Messed output of Elf.PrintSectionInfo(0)
    • [SOLVED] Messed output of Elf.PrintSectionInfo(0)
      Ozone version: 3.28d
      I see that this error happens in different projects, so there is no special MRE.
      Steps
      1. Build a C project, generate .elf file
      2. Start Ozone, open Console
      3. Load the project, among others there is a list of program segments dumped to the Console:
      1. File.Open: completed in 1262 ms
      2. Program segments:
      3. Address Size Code RO Data RW Data ZI Data Flg
      4. --------- --------- --------- --------- --------- --------- ---
      5. 08000000 457 792 360 232 97 560 0 0 RWE
      6. 20000000 40 220 0 0 20 392 19 828 RW
      7. 20009D1C 1 540 0 0 1 540 0 RW
      8. --------- --------- --------- --------- --------- --------- ---
      9. Total: 499 552 360 232 97 560 21 932 19 828
      10. --------- --------- --------- --------- --------- --------- ---
      11. For further information on ELF file data sections, execute command Elf.PrintSectionInfo(0).
      4. Now execute Elf.PrintSectionInfo(0), note the messed formatting:
      1. Data sections:
      2. Name Address Code RO Data RW Data ZI Data
      3. ----------------- ----------------- ----------------- ----------------- ----------------- -----------------
      4. ._user_heap_stack 20009D1C 0 0 1 540 0
      5. .ARM 08073C50 0 0 0 0
      6. .ARM.extab 08073B90 0 192 0 0
      7. .bss 20004FA8 0 0 0 19 828
      8. .data 20000000 0 0 20 392 0
      9. .fini_array 08073DE8 0 0 0 0
      10. .init_array 08073DD8 0 0 0 0
      11. .isr_vector 08004000 0 432 0 0
      12. .preinit_array 08073DD8 0 0 0 0
      13. .rodata 0805C0E8 0 96 936 0 0
      14. .text 080041C0 360 232 0 0 0
      15. ----------------- ----------------- ----------------- ----------------- ----------------- -----------------
      16. Total: 360 232 97 560 21 932 19 828
      17. ----------------- ----------------- ----------------- ----------------- ----------------- -----------------
      18. Elf.PrintSectionInfo (0); // returns 0x0
      Kind regards,
      Vadim B
    • Hi Vadim B,
      thanks for notifying us. We will provide a fix with a future Ozone version.
      -- AlexD
