[SOLVED] Project command specified twice: Target.LoadMemoryMap
  • [SOLVED] Project command specified twice: Target.LoadMemoryMap
    I get an unexpected message Project command specified twice: Target.LoadMemoryMap.
    The relevant part of the command file:
    1. void OnProjectLoad (void) {
    2. int debug;
    3. debug = 0;
    4. Project.SetDevice ("STM32L496VG");
    5. Project.SetHostIF ("USB", "");
    6. Project.SetTargetIF ("SWD");
    7. Project.SetTIFSpeed ("4 MHz");
    8. Project.AddPathSubstitute ("/home/vadim/work/PROJECT", "$(ProjectDir)");
    9. if (debug == 1) {
    10. File.Open ("$(ProjectDir)/build/dev/PROJECT.elf");
    11. Target.LoadMemoryMap ("$(ProjectDir)/build/dev/PROJECT.map");
    12. } else {
    13. File.Open ("$(ProjectDir)/build/rel/PROJECT.elf");
    14. Target.LoadMemoryMap ("$(ProjectDir)/build/rel/PROJECT.map");
    15. }
    16. }
    Console output:
    1. Disabled output of control characters
    2. SEGGER Ozone - The J-Link Debugger V3.28d
    3. J-Link software found at: /opt/SEGGER/Ozone_Linux_V328d_x86_64/Lib/libjlinkarm.so
    4. File.Open ("/home/vadim/work/PROJECT/ozone-PROJECT.jdebug");
    5. Project.SetDevice ("STM32L496VG");
    6. Project.SetHostIF ("USB", "");
    7. Project.SetTargetIF ("SWD");
    8. Project.SetTIFSpeed ("4 MHz");
    9. Project.AddPathSubstitute ("/home/vadim/work/PROJECT", "$(ProjectDir)");
    10. File path resolved: "$(ProjectDir)/build/rel/PROJECT.elf" was found at "/home/vadim/work/PROJECT/build/rel/PROJECT.elf"
    11. File.Open ("/home/vadim/work/PROJECT/build/rel/PROJECT.elf");
    12. Target.LoadMemoryMap ("$(ProjectDir)/build/rel/PROJECT.map");
    13. File path resolved: "$(ProjectDir)/build/rel/PROJECT.map" was found at "/home/vadim/work/PROJECT/build/rel/PROJECT.map"
    14. Project command specified twice: Target.LoadMemoryMap.
    Am I doing anything wrong?
    Kind regards,
    Vadim B
  • Hi Vadim B,
    you're not really doing anything wrong. However, your usage of the Target.LoadMemoryMap() command in the if/else construct is beyond mainstream usage.
    This construct leads to Target.LoadMemoryMap() being present twice in your OnProjectLoad() function. And this is what the routine, that finally leads to the warning "Project command specified twice" being printed, actually checks for: The presence of multiple such statements. In particular, the routine does not check whether the command was actually executed twice.
    So in your case you may safely ignore that warning.
    You may also consider reworking your Ozone script: Normally, release code does not provide debug information, so operating a debugger on such code is of rather limited use.
    -- AlexD
  • You're very welcome. I'll close this thread now.
