[SOLVED] ITM output in release version
  • [SOLVED] ITM output in release version
    I have a strange problem where ITM is not shown in the release version of program in the ses console. My configuration seems the same for both debug and release.
    Before I start disecting config file.
    Is ITM supported in release version? I dont see why it would be disabled. ?(
    In release build configs usually code optimization is enabled for the compiler.
    Depending on how and where your ITM prinf calls are written and how aggressive the compiler optimizes it is possible that it will simply throw the printf calls out.
    Try experimenting with the different optimization levels. There are also "tricks" in C which can be applied so the compiler won't throw certain code away. For that there are multiple different guides in the internet.
