[SOLVED] Setting up Ozone with J-link pro first time. Having issue with 1) FreeRTOSPlugin.js 2) Attach
  • [SOLVED] Setting up Ozone with J-link pro first time. Having issue with 1) FreeRTOSPlugin.js 2) Attach
    I am a new user and trying to setup Ozone with J-link Pro. I am running into few errors a following. Kindly help.
    Platform - Xilinx Ultrascale+ (CORTEX-A53), OS - FreeRTOS.
    I started ozone with device = CORTEX-A53, Target interface = JTAG, Host interface = USB.
    First it complained about not being able to find out FreeRTOSPlugin.js/dll. I looked up Ozone install folder for the OS plugin. I noticed varied flavors of FreeRTOS_***.js are present. To keep Ozone happy, I renamed FreeRTOSPlugin_ARM.js to FreeRTOSPlugin.js. Which allowed Ozone to proceed.
    However, when I tried to attach using Debug ->start debugging session -> attach to running program (as well as Attach n Halt program), I get following errors.
    Please help, how can I attach the running app and/or start debugging (my App) on target.
    Thank you!
    Debug.SetConnectMode (CM_ATTACH);
    Debug.Start();
    Device "CORTEX-A53" selected.
    TotalIRLen = 16, IRPrint = 0x000751
    JTAG chain detection found 2 devices:
    #0 Id: 0x00000001, IRLen: ?, Unknown device
    #1 Id: 0x14730093, IRLen: ?, Unknown device
    Connect failed. Resetting via Reset pin and trying again.
    CPU-TAP not found in JTAG chain
    Connection failed.
  • Hi Ekengr,
    please open a support ticket against J-Link in our ticket system. For doing so, please follow the link in my the footer of my post.
    -- AlexD
  • Hi again, ekengr,
    The FreeRTOS topic is not related to the connection topic. For details on how to include the FreeRTOS plug-in please refer to section 7.9.14.10 in the Ozone user's manual.
    You should not rename the .js-file but adapt the statement in your Ozone project file so it matches the MCU architecture you use.
    -- AlexD
