[SOLVED] SES 7.10 - Allow use StudioUserDir for system libraries
  • [SOLVED] SES 7.10 - Allow use StudioUserDir for system libraries
    After updated to SES 7.10, the pre-built libraries are not shipped with SES any more, instead they are built from source as needed.
    This is nice, however on Linux the /opt directory is not always writable or access is limited to certain users.
    Are there any options to change the system libraries' output to other directories, e.g. $(StudioUserDir)/lib ?
    * EDIT*
    The typical use case is multiple users are sharing an SES installation, and the libraries created with one user's UID and GID are not writable to another user.
    Thanks & Best Regards,
    Yilin Sun
  • Hello Yilin Sun,
    Thank you for your feedback.
    Currently there are not options available to achieve this.
    However we see that a solution for this might be necessary, so we will discuss this in the team and come back to you once we got more information.
    Best Regards,
    Lucas
    Our engineers will try to answer your questions between their projects if possible but this can be delayed by longerperiods of time.
    Should you be entitled to support you can contact us via our support system: segger.com/ticket
