After sending Jlink command "power on perm", the voltage at Jlink Pin2 (Vsupply 20 Pin) output should be 5.0 Volts, but it is output 0 volt.
When I connect Pin 2 with pin19(DBGACK), then Pin 2 output is 5.0Volt.
Why should Pin 19 connect to Pin2 to output 5V volt?
