[SOLVED] Data Sampling not working
  • [SOLVED] Data Sampling not working
    I am trying to graph a variable with the Data Sampling feature but Ozone does not sample any values, I know that it was working in the past. The Watch window refresh is working and RTT is also working so background memory access itself works.
    Whenever I change the sampling frequency a new value is recorded but nothing more. I am using Ozone V3.28c, Segger Jlink Package V7.84d and a j-Trace Pro for Arm Cortex-M running the lasted Firmware compiled 23.01.2023. I attached a gif showing this behaviour.
    PS: J-Scope shows the same behaviour, I can select the variable but no values are recorded.
    What target device are you running on?
    Could you provide an example project for reproduction that could run on an eval board?
    What is the S/N of your J-Trace Pro?
  • I tried to create a minimal example showing the issue but now it is working again. Also the original project (which I changed in the mean time) is working again, including J-Scope. I don't know what happened and I am not able to reproduce it again.
  • Hi JulianR,
    in case this phenomenon re-appears, feel free to contact us again.
    -- AlexD
