[SOLVED] JLinkDevices folder is not deep searched on Linux
  • [SOLVED] JLinkDevices folder is not deep searched on Linux
    The wiki page (J-Link Device Support Kit - SEGGER Wiki) says "Customers may freely structure the folder into subfolders with a maximum depth of 4"
    This feature works fine on Windows. For example, the following structure works:
    1. Roaming
    2. - SEGGER
    3. - JLinkDevices
    4. - folder1
    5. - folder2
    6. - devices.xml
    However, such a structure doesn't work on Linux:
    1. .config
    2. - SEGGER
    3. - JLinkDevices
    4. - folder1
    5. - folder2
    6. - devices.xml
    Whereas this does work:
    1. .config
    2. - SEGGER
    3. - JLinkDevices
    4. - devices.xml
    It looks like the Linux version is missing this search depth feature, so it only looks for XML files at the JLinkDevices directory.
    I'm using V7.84b.
    Sorry for the late reply.
    I cannot confirm this. Just tested this under Linux Mint and the deep search is working correctly, as far as I can see:
    I have something to add:
    While I do not see how it could happen that directories were not deep searched,
    I could identify a bug that caused directories above $HOME/.config/SEGGER/JLinkDevices were also searched by accident.
    This will be fixed in V7.86b which is going to be released later today.
    Maybe worth a try to check if that solves the issue you are seeing as well.
