[SOLVED] printf issue when using \n (since V7.68b)
  • [SOLVED] printf issue when using \n (since V7.68b)
    There is a regression that appeared in 7.68b, when using printf with LF to display logs under Eclipse using GDB Segger Jlink.
    Globally, when doing a printf containing a \n, the last 4 characters are repeated after the LF.
    Easier to explain with an example :
    printf("Flash drivers demo"\n);
    printf("- Initialize flash driver");
    printf("-> OK\n");
    I get this in Eclipse console:
    SEGGER J-Link GDB Server V7.68a - Terminal output channel
    Flash drivers demo
    - Initialize flash driver -> OK
    SEGGER J-Link GDB Server V7.68b - Terminal output channel
    Flash drivers demo
    demo
    > OK
    If it can help the issue disappears when using \r instead of \n
    (could be a workaround, but unfortunately in that case it does not work anymore with other IDEs such as IARW).
    Below some details, let me know if you need more:
    SEGGER J-Link GDB Server V7.68b Command Line Version
    JLinkARM.dll V7.68b (DLL compiled Jul 22 2022 17:24:21)
    Frederic
  • We have fixed an issue in yesterday's version V7.84e that caused similar behavior.
    Can you please give it a try and confirm that it solves the issue you are describing, as well?
    segger.com/downloads/jlink/#J-…twareAndDocumentationPack
