SFL ISSUE : STM32H7B3 EVAL Board with a Non Default External OSPI Flash (Micron) - RAMCode did not respond in Time
    • SFL ISSUE : STM32H7B3 EVAL Board with a Non Default External OSPI Flash (Micron) - RAMCode did not respond in Time
      The Driver for the New External Flash has been Unit tested on the SFL project and does all core(mandatory) functions work OK.
      same ELF generated from this project in kept in path <C:\Users\XXX\AppData\Roaming\SEGGER\JLinkDevices> and Jlink when launched Connects "Successfully"
      to my newly added Entry in “Target Device” , But when I try to use the Read (target->Manual Programming->Read Back -> selected Sectors)
      I get this below message:
      " Timeout while blank checking, RAMCode did not respond in time!
      Failed to blank checking.
      Failed to execute blank checking"
      Looks like this is a common issue in the recent posts; but no post has a solution updated. any updates on this ?
