[SOLVED] Extend SystemView tartget printf interfaces with vprintf APIs
  • [SOLVED] Extend SystemView tartget printf interfaces with vprintf APIs
    Hi Segger Team,
    it would be very nice to add APIs for the printf functions with va_list* pParamList instead of ... for target so upper layer software can pass on parameters passed to them via ....
    We currently do this by patching the files to directly exposing _VPrintTarget to the header (making this function global).
    As this solution isn't the right manner and we like to have this in the original release i propose following changes to SystemView:
    C Source Code: SEGGER_SYSVIEW.h
    2. *
    3. * printf-Style functions
    4. */
    5. #ifndef SEGGER_SYSVIEW_EXCLUDE_PRINTF // Define in project to avoid warnings about variable parameter list
    6. void SEGGER_SYSVIEW_PrintfHostEx (const char* s, U32 Options, ...);
    7. void SEGGER_SYSVIEW_PrintfTargetEx (const char* s, U32 Options, ...);
    8. void SEGGER_SYSVIEW_VPrintfTargetEx (const char* s, U32 Options, va_list* pParamList);
    9. void SEGGER_SYSVIEW_PrintfHost (const char* s, ...);
    10. void SEGGER_SYSVIEW_PrintfTarget (const char* s, ...);
    11. void SEGGER_SYSVIEW_VPrintfTarget (const char* s, va_list* pParamList);
    12. void SEGGER_SYSVIEW_WarnfHost (const char* s, ...);
    13. void SEGGER_SYSVIEW_WarnfTarget (const char* s, ...);
    14. void SEGGER_SYSVIEW_VWarnfTarget (const char* s, va_list* pParamList);
    15. void SEGGER_SYSVIEW_ErrorfHost (const char* s, ...);
    16. void SEGGER_SYSVIEW_ErrorfTarget (const char* s, ...);
    17. void SEGGER_SYSVIEW_VErrorfTarget (const char* s, va_list* pParamList);
    18. #endif
    Source Code: SEGGER_SYSVIEW.c
    2. *
    3. * SEGGER_SYSVIEW_VPrintfTargetEx()
    4. *
    5. * Function description
    6. * Print a string which is formatted on the target before sent to
    7. * the host with Additional information.
    8. *
    9. * Parameters
    10. * s - String to be formatted.
    11. * Options - Options for the string. i.e. Log level.
    12. * pParamList - Pointer to the list of arguments for the format string
    13. */
    14. void SEGGER_SYSVIEW_VPrintfTargetEx(const char* s, U32 Options, va_list *pParamList) {
    15. _VPrintTarget(s, Options, pParamList);
    16. }
    2. *
    3. * SEGGER_SYSVIEW_VPrintfTarget()
    4. *
    7. * the host.
    8. *
    9. * Parameters
    11. * pParamList - Pointer to the list of arguments for the format string
    12. */
    13. void SEGGER_SYSVIEW_VPrintfTarget(const char* s, va_list* pParamList) {
    14. _VPrintTarget(s, SEGGER_SYSVIEW_LOG, pParamList);
    15. }
    and so on
    I can provide proper patch files if you like?
    Philipp Häfele
  • Hello Phillip,
    Sounds reasonable to me.
    Could you provide the patch files via our support channel as explained in my signature so we can take a look?
  • Hi Nino,
    no problem, will create a ticket with the patch files for it.
    Just found this forum better for discussion, as the Segger GitHub repo is somehow abandoned.
    May take a little bit, as i haven't prepared the patch right now and i'm out of office for some time soon.
    Philipp
  • Hi Phillip,
    You can also share the patches here of course.
