[SOLVED] [Version 7.10] Build issues:undefined reference to stdout
  • [SOLVED] [Version 7.10] Build issues:undefined reference to stdout
    I am aiming to compile a project with SES studio, version 7.10 on linux. The target is nRF52840.
    I have the following issue:
    1.
    Compiling 'SEGGER_RTT_Syscalls_SES.c'
    __vfprintf.h: No such file or directory
    Build failed
    I did some research and found the solution of removing SEGGER_RTT_Syscalls_SES.c from build system. This resolve this issue above but then there is another issue :
    2.
    Generating linker script 'PROJECT_NAME..ld'
    Linking PROJETCT_NAMEelf
    /opt/segger/segger_embedded_studio_for_arm_7.10/lib/libc_v7em_fpv4_sp_d16_hard_t_le_eabi_balanced.a(fileops.o): in function `putchar':
    fileops.c:(.text.libc.putchar+0x0): undefined reference to `stdout'
    fileops.c:(.text.libc.putchar+0x4): undefined reference to `stdout'
    /opt/segger/segger_embedded_studio_for_arm_7.10/lib/libc_v7em_fpv4_sp_d16_hard_t_le_eabi_balanced.a(fileops.o): in function `puts':
    fileops.c:(.text.libc.puts+0x2): undefined reference to `stdout'
    fileops.c:(.text.libc.puts+0x6): undefined reference to `stdout'
    fileops.c:(.text.libc.puts+0x18): undefined reference to `__SEGGER_RTL_X_file_write'
    /opt/segger/segger_embedded_studio_for_arm_7.10/lib/libc_v7em_fpv4_sp_d16_hard_t_le_eabi_balanced.a(fileops.o): in function `fwrite':
    fileops.c:(.text.libc.fwrite+0xc): undefined reference to `__SEGGER_RTL_X_file_stat'
    fileops.c:(.text.libc.fwrite+0x24): undefined reference to `__SEGGER_RTL_X_file_write'
    Build failed
    From there, I could not find any thread exactly providing a fix. SOme people have observed similar issue. It seems that reverting back to SES 5.22 will work but I would like to support more recent version of the IDE.#
    Can you please avise on path to resolution ?
    There were some changes in the major releases on how the I/O libraries are linked into your projects.
    So if you are porting an old project to a newer ES version you have to make sure that the correct I/O library is selected.
    For more information see here:
    wiki.segger.com/Embedded_Studio_Library_IO
