[emWin]How do I output a bmp image with a transparent color to the LCD?
    • [emWin]How do I output a bmp image with a transparent color to the LCD?
      Dear all,
      I'd like to print the bmp-picture with transparent RGB-color value(0xFF00FF) on the background bmp and then print them all on the LCD.
      How do I implement it with emWin?
      image-data(testbg.bmp and num_w....bmp) are 16bit, 565 formated bmp.
      When I try test_trans1 function as below , transparent area also printed on lcd.
      //-----------------------TEST CODE--------------------//
      void test_trans1(....){
      GUI_SelectLayer(1);
      hMem = GUI_MEMDEV_CreateEx(x0, y0, xSize, ySize, GUI_MEMDEV_HASTRANS);
      GUI_MEMDEV_Select(hMem);
      GUI_SetBkColor(0xFFFF00FF);//Transparent Color?
      for(int i=0; i< max_images; i++){
      // set "bm_array" and "Bmp" with bmp-info
      GUI_DrawBitmap( (GUI_BITMAP*)&bm_array, &Bmp[i]->Left, (&Bmp[i]->Top) );
      GUI_MEMDEV_Select(0);
      GUI_MEMDEV_CopyToLCD(hMem);
      GUI_MEMDEV_Delete(hMem);
      Do anyone happen to know what's problem on emWin lib?
      Actually this kind of job to manipulate transparent color, is not that difficult,
      but It's frustrating that I can't check inside of draw function.
      Thanks in advance for your help.
      Best Regards,
      Tommy
        (1.11 kB, downloaded 293 times, last: )
        (1.11 kB, downloaded 334 times, last: )
      The post was edited 2 times, last by Tommy lim ().
      I'm wondering if "bm_array" is an actual BMP image file? Please note that the GUI_DrawBitmap() function is only for C bitmaps (the GUI_BITMAP structure), not actual BMP files.
      BMP images have to be drawn with the GUI_BMP_... API functions. You can find an example in our wiki on how to draw a BMP image file.
      Florian
