A way to make emWin use an external SDRAM instead of internal RAM
    • A way to make emWin use an external SDRAM instead of internal RAM
      I'm using a library version of emWin, but I would like to ask if there is a way/option to make emWin use an external SDRAM instead of internal RAM.
      For the application part, I think I can use compiler/linker options (#pragma or something).
      Thanks in advance.
      Best Regards,
      Rowel
      You have to link the "GUI-memory" into the SDRAM. How this is done depends our your linker.
      emWin will allocate memory only from the block set with GUI_ALLOC_AssignMemory().
      Here is an example from a GUIConf.c which does it.
      1. #include "GUI.h"
      3. *
      4. * Defines
      5. *
      7. */
      8. //
      9. // Define the available number of bytes available for the GUI
      10. //
      11. #define GUI_NUMBYTES (1024 * 1024 * 4)
      12. #if (defined __ICCARM__) // IAR
      13. static __no_init U32 aMemory[GUI_NUMBYTES / 4] @ "GUI_RAM";
      14. #elif (defined __SES_ARM) // SES
      15. static U32 aMemory[GUI_NUMBYTES / 4] __attribute__ ((section (".GUI_RAM")));
      16. #else
      17. static U32 aMemory[GUI_NUMBYTES / 4];
      18. #endif
      19. /*********************************************************************
      20. *
      21. * Static code
      22. *
      23. **********************************************************************
      24. */
      25. /*********************************************************************
      26. *
      27. * Public code
      28. *
      29. **********************************************************************
      30. */
      31. /*********************************************************************
      32. *
      33. * GUI_X_Config
      34. *
      35. * Purpose:
      36. * Called during the initialization process in order to set up the
      37. * available memory for the GUI.
      38. */
      39. void GUI_X_Config(void) {
      40. //
      41. // Assign memory to emWin
      42. //
      43. GUI_ALLOC_AssignMemory(aMemory, GUI_NUMBYTES);
      44. }
      If you are using the GUIDRV_Lin driver you might also want to link the frame buffer to the external memory. This is most likely done the same way as with the "GUI-memory".
