[SOLVED] J-Flash readrange behavior different with GUI and command line
  • [SOLVED] J-Flash readrange behavior different with GUI and command line
    When using JFlash to read memeory, input NumBytes parameter to Blankcheck is different. By command line, it always be 4 and by GUI, it will be the actual bytes from range.
    Is it normal? Thanks.
    By command line:
    "C:\Program Files\SEGGER\JLink\JFlash.exe" -openprjmytest3.jflash /min /wait -connect -readrange,0x10078000,0x1007FFFF
    Result log:
    Reading target memory (0x10078000 - 0x10078000) ...
    - Start of determining flash info (Bank 0 @ 0x10078000)
    - End of determining flash info
    - Flash bank info:
    - 8 * 4 KB @ 0x10078000
    - Start of preparing flash programming
    - End of preparing flash programming
    - [b]Blank checking 0x10078000 - 0x10078003[/b]
    - Start of restoring
    - End of restoring
    - Target memory read successfully. (4 bytes, 1 range) - Completed after 0.103 sec
    J-Flash V7.80: Target memory read successfully. (4 bytes, 1 range) - Completed after 0.103 sec
    By GUI:
    Target -> Manual Programing -> Read Back -> Range -> 0x10078000 - 0x1007FFFF
    Result log:
    [tt]Reading target memory (0x10078000 - 0x1007FFFF) ...
    - Flash bank info:
    - [b]Blank checking 0x10078000 - 0x1007FFFF[/b]
    - End of restoring
    - Target memory read successfully. (32768 bytes, 1 range) - Completed after 0.281 sec
  • Remember that Segger's command line utility options have the unusual requirement that parameters to options must follow the option with no whitespace or punctuation.
    Try this command line:
    1. "C:\Program Files\SEGGER\JLink\JFlash.exe" -openprjmytest3.jflash /min /wait -connect -readrange0x10078000,0x1007FFFF
    I can't guess a reason why the utility interprets "-readrange,0x10078000,0x1007FFFF" as a 4 byte read starting from 0x10078000 other than it's confused by that first comma.
  • @sharon Good to hear that you are up and running
    @mwb1100 It is not really an unusual requirement of "SEGGER's command line utility" but more a J-Flash specific thing. We are in the process of changing that to make it more standard but at the same time keep backward compatibility. The J-Flash command line was designed ages ago and is indeed somewhat weird at some points.
