[ABANDONED] ​J-link PRO: Interrupt setup problem??
  • [ABANDONED] ​J-link PRO: Interrupt setup problem??
    I am using an NXP S32K344EVB-Q172 for firmware development, using primarily NXP RTD firmware plus my application code with IAR Embedded Workbench. I can flash the code and run / debug using the on-board PEmicro debugger.
    I am trying to switch over to the J-link PRO debugger we will use with our target board. I can connect the J-link PRO and download the code with no problems, but when the interrupt setup code is executed and I attempt to write to the NVIC to enable the interrupt (the first one is PIT_0) with the following line of code:
    S32_NVIC->ISER[(uint32)(eIrqNumber) >> 5U] = (uint32)(1UL << ((uint32)(eIrqNumber) & (uint32)0x1FU));
    The processor goes to an undefined_handler routine:
    void undefined_handler(void)
    while(TRUE){};
    This behavior occurs on the SDK I'm using, and I have also observed it with my target board.
    This does NOT occur when I use the on-board PEmicro debugger, so I suspect I've got something improperly set. The J-link PRO seems to be unable to properly set interrupts.
    Any assistance would be greatly appreciated. Thank you in advance.
  • We do not see why this should not work.
    Would it be possible to get your project that can run on the S32K344EVB-Q172 and allows reproduction of the problem?
