[SOLVED] I would like to know what library is used to programmatically read custom variable structure information in ELF files?
  • [SOLVED] I would like to know what library is used to programmatically read custom variable structure information in ELF files?
    a ELF file contains debug info, then the types of variables, structures, and great many other kinds of info can be extracted from that binary.Theoretically possible, but I don't know how to program the implementation by c language
    For example if I have an embedded struct and variable like this:
    typedef struct
    unsigned int varA;
    unsigned int varB;
    }T_myStruct;
    T_myStruct data;
    I want to get the address and type of not only data, but preferably data.varA and data.varB. I used segger ELFlib without success, and I was wondering if there was a more suitable library.
  • If the variable is a static / global one and therefore is valid over the whole program lifetime, SEGGER ELFLib is the way to go.
    If it is a local one, things get more complicated because it is located on the stack and only valid while in scope.
    It also does not have any fixed absolute address then but is located relative to the stack frame of the function it is in.
    If you have licensed the ELFLib, did you consider issuing an official support ticket when running into an issue?
