[SOLVED] Determine if function is called from Timer or interrupt
  • [SOLVED] Determine if function is called from Timer or interrupt
    Hello.
    I am using EmbOS CortexM GCC V5.02 on an ATSAM4E8C.
    I have a function which I would like to take different code paths if called from a thread or from a timer or interrupt handler.
    Basically my function is normally called from a task, but because it uses a MUTEX, this will fail with OS Error 161 if called from a timer handler or 160 if called from an ISR.
    Is it possible to determine if my function is called from a timer or interrupt handler, so I can take a different code path, avoiding trying to acquire the mutex?
    I would like to do something like the following:
    1. if (OS_InTimerHandler() || OS_In_ISR()) {
    2. do_something_special();
    3. } else {
    4. if (0==OS_MUTEX_LockTimed(&my_mutex, 100)) {
    5. error_mutex_timeout();
    6. } else {
    7. do_something_that_requires_mutex();
    8. OS_MUTEX_Unlock(&my_mutex);
    9. }
    10. }
    Note: The function also performs a number of other things before and after the mutex, so replacing all calls from within timer and interrupt handlers with a special version is not desirable.
    Mikkel Holm Olsen
  • Hello Mikkel,
    with the most recent embOS version you can use OS_TIMER_GetCurrent() and OS_INT_InInterrupt().
    With older embOS versions the return value of OS_TIMER_GetCurrent() was valid during the execution of a timer callback function only.
    segger.com/doc/UM01001_embOS.html#OS_TIMER_GetCurrent
    segger.com/doc/UM01001_embOS.html#OS_INT_InInterrupt
    Would it be possible for you to update to the latest embOS Cortex-M GCC V5.18.0.1?
    That would be the easiest solution.
    Til
