[SOLVED] RTT viewer not in a web page
  • [SOLVED] RTT viewer not in a web page
    Hi All
    does anyone know how i can get the old RTT app working again... the newer web client app sucks... it is a pain to connect and disconnect it doesn't display things properly any more ... i just want what i use to have that worked
    the rtt windows for send and receive are reducioulos and you have to check the CR and LF boxes to get them to work.... argggg....
    it use to be a great tool... not its useless and costs loads of time and frustration.... who ever thought that this would be a good idea needs to actually use it for some tricky debugging... with problems at startup
    this was such a step backwards...
    and in my automatic test equipment in the service bar i end up with 100 icons per hour that just build up and you have to hover over them to make them dissapear...
    The RTT tab in the J-Link web control panel did not replace the RTT Viewer.
    It is just some additional feature for the web control panel and in no means designed to
    come close to the J-Link RTT Viewer.
    The J-Link RTT Viewer is still available as application for Windows, Linux and MacOS:
    wiki.segger.com/J-Link_RTT_Viewer
    It is part of the J-Link Software Pack (JLinkRTTViewer.exe / JLinkRTTViewerExe):
    Could you please check?
