I have a target that will be programmed with a Base Compact. I have a computer connected to the programmer via USB. The software I use likes more a COM-port so I have activated the VCOM future.
I need to read the UUID from the target. I need to program the target. I also need to include the production date in the HEX.
I have tested a script-flle (*.jlink) that (only) program the target and that works.
However, can I send commands through the COM-port instead of using command files OR do the test software need to use jlink.exe with a command file as parameter?
Of course, If you can give me a tip how to read UUID it would be great.
As you understand, I'm a newbee regarding Seggers software package and I hope this forum can get me going.
