[SOLVED] Ozone debugging Portenta H7 - add mbed OS view window
  • [SOLVED] Ozone debugging Portenta H7 - add mbed OS view window
    I added the following to by .jdebug file - specifically the last line
    1. void OnProjectLoad (void) {
    2. //
    3. // Dialog-generated settings
    4. //
    5. Project.AddPathSubstitute ("Z:/User/SALASOFT/Constr/Envirowatch/Code/MainCode/EnviroWatch", "$(ProjectDir)");
    6. Project.AddPathSubstitute ("z:/user/salasoft/constr/envirowatch/code/maincode/envirowatch", "$(ProjectDir)");
    7. Project.SetDevice ("STM32H747XI_M7");
    8. Project.SetHostIF ("USB", "175102672");
    9. Project.SetTargetIF ("SWD");
    10. Project.SetTIFSpeed ("4 MHz");
    11. Project.AddSvdFile ("$(InstallDir)/Config/CPU/Cortex-M7F.svd");
    12. //
    13. // User settings
    14. //
    15. File.Open ("C:/Users/RS/AppData/Local/Temp/arduino-sketch-FFBA7C5D8784E913A256FD1018B9CBF5/EnviroWatch.ino.elf");
    16. Project.SetOSPlugin("embOSPlugin.dll");
    17. }
    I see the embed OS tab on View, and when opening it all I get is a blank screen.
    Is there some issue of the plugin on the mbed configuration of the portenta?
    I did not install or do anything with the .js embed plugin code - presumably that is called by the window itself?
    Let me know if there is anything else I can try to get a look at al my threads.
  • My mistake -= I did not realize that embOS is the Segger real time OS and not ARM MBed.
    in any case, my original question requiring the viewing of thread info of the Portenta, running MBed OS still stands.
    Is this possible?
    The post was edited 1 time, last by rs77can ().
    Correct embOS is our own RTOS so the plugin would not work with other RTOS's.
    Generally it is possible to view RTOS info of any RTOS in Ozone. But you need to supply a plugin so Ozone knows where to look for task/thread information of your RTOS.
    For this Ozone has an open JavaScript based interface which you can use to create your own RTOS awareness plugin.
    How is described in the Ozone manual in chapters 6.3 and 7.10.
