[SOLVED] GigaDevice GD32F3x0 protection/security
  • [SOLVED] GigaDevice GD32F3x0 protection/security
    I need to program GD32F310F4/8 devices in production via SWD and miss the security feature which seems to be missing for all GD32F3x0.
    These two option byte registers OB_SPC/OB_SPC_N cannot be written from .hex file and there is no project option to set them.
    1. 0x1ffff800 OB_SPC
    2. option byte Security Protection Code
    3. 0xA5: No protection
    4. any value except 0xA5 or 0xCC: low level protection
    5. 0xCC: high level protection
    6. 0x1ffff801 OB_SPC_N OB_SPC complement value
    Writing them seems is possible via FMC_WP register.Is there a way to support this or another way to set these during mass programming? I don't want to set these in firmware for flash memory reduction.
    Thanks in advance & best regards,
  • Hi Alex,
    I assume you are using J-Flash for programming?
    In this case, you can use the Exit steps in the J-Flash project options.
    The GD32F1 devices have mostly the same option byte programming procedure as the STM32F1 do.
    There is a J-Flash project in the SEGGER wiki that sets RDP for the STM32F1 via the exit steps.
    After some small adjustments, it should also work for the GD32F1 devices.
