[SOLVED] Erase STM32F413VH JLINK sw > 7.00
  • Erase STM32F413VH JLINK sw > 7.00
    Hello!
    I use J-Link Plus HW10.1.
    I recently upgraded J-Link software to version 7 and ran into a memory cleanup error issue. The last four sectors in STM32F413VH are not cleared.
    I did some research, installed software versions from 7.00 to 7.68b, both 32 and 64 bits. The last correctly working version is 6.98e.
    J-Flash and J-Flash Lite give the same memory clearing error when trying to clear the last 4 sectors.
    At the same time, before cleaning, a message is displayed stating that the controller is write-protected and it is proposed to remove the protection. However, the write protection is not removed.
    It helps only clearing these security bits through the ST-Link emulator and their software.
    I tried updating the J-Link firmware, both to the latest and to the 2019 version, there is no difference.
    If the controller was locked, then I can no longer clear it, even if I remove version 7 software and try to do it through version 6, it will give the same error and clear nothing.
    Please check and fix this annoying bug in your software.
    The post was edited 1 time, last by Turnaev ().
  • [SOLVED] Erase STM32F413VH JLINK sw > 7.00
    I checked J-Link base HW 9.3 too, it is exactly the same error.
    The problem is very serious. If my colleague did not have a ST-Link emulator, I would have to throw away these controllers and replace them with new ones.
    How can I change the option bytes for this microcontroller in your software?
    The post was edited 4 times, last by Turnaev ().
    I can confirm that this is a bug in our software.
    A fix will be part of the patched release, planned for later today.
