[SOLVED] J-Flash V7.68a - ERROR: Flash bank @ 0x00000000 is not supported in stand-alone mode
  • [SOLVED] J-Flash V7.68a - ERROR: Flash bank @ 0x00000000 is not supported in stand-alone mode
    Setup:
    Flasher-ARM
    J-Flash V7.68a
    NXP K81(or K82) with QSPI.
    SWD @ 4000KHz
    Attempting:
    File->Download config & data file to Flasher
    Get this:
    Downloading file(s) to probe / programmer...
    - Checking if selected data fits into selected flash sectors.
    - Preparing DAT file range: 0x00000000 - 0x000007FF (2048 bytes).
    - Preparing DAT file range: 0x00000800 - 0x00000FFF (2048 bytes).
    -------/ CUT /--------
    - Preparing DAT file range: 0x0003D000 - 0x0003D7FF (2048 bytes).
    - Preparing DAT file range: 0x0003D800 - 0x0003DE1F (1568 bytes).
    - Preparing DAT file range: 0x68060000 - 0x680607FF (2048 bytes).
    - Preparing DAT file range: 0x68060800 - 0x68060BFF (1024 bytes).
    - Preparing DAT file range: 0x68064000 - 0x680647FF (2048 bytes).
    - Preparing DAT file range: 0x68070000 - 0x680707FF (2048 bytes).
    - Preparing DAT file range: 0x68070800 - 0x680709FF (512 bytes).
    - Connecting via USB to probe/ programmer device 0
    - Probe/ Programmer firmware: J-Link ARM / Flasher ARM V4 compiled Jun 15 2022 11:03:00
    - Downloading "Flasher.dat" (270880 bytes) to Programmer ...
    - Downloading (270880 bytes, CRC: 0xE6884E50) ...
    - Downloading "Flasher.cfg" (32768 bytes) to Programmer ...
    - Downloading (32768 bytes, CRC: 0xE1CEFA0F) ...
    - Removing "Flasher\Reset.pex" from Programmer...
    - Removing "Flasher\Connect.pex" from Programmer...
    - Removing "Flasher\Unsecure.pex" from Programmer...
    - Removing "Flasher\Setup.pex" from Programmer...
    - Downloading "Flasher\Device.pex" (3656 bytes) to Programmer ...
    - Downloading (3656 bytes, CRC: 0x0F095AFE) ...
    - ERROR: Failed to download files
    Flash bank @ 0x00000000 is correct for the internal flash on the K8x. I am able to program the board using J-Link Commander:
    J-Link> loadfile c:\tests\TestFw.hex
    Is this a bug, or am I overlooking a setting somewhere?
    Denis
    The post was edited 1 time, last by DenisCollis: typos ().
  • Hi Denis,
    this is a bug that was already fixed internally.
    The fix will be part of the next patched release, planned for later today (V7.68b).
    If you want to be notified when the patched version goes live, you can subscribe to our release newsletter:
    segger.com/notification/subscribe.php?prodid=7,94
    We are sorry for any inconvenience caused.
