[ABANDONED] J-Link reset via reset pin fails
  • [ABANDONED] J-Link reset via reset pin fails
    I was able to flash my MK64FN1M0XXX12 processor using J-Link until I flashed code which apparently reconfigured the debug pins. Now connecting to the device fails even after resetting via the debug pin. Is there still a way for J-Link to connect to the device?
    Just to rule this out:
    Did you make sure that the RESET-pin is connected between J-Link and MCU?
    For the connect under reset this is absolutely necessary.
