[ABANDONED] unions with structs dont display properly
  • [ABANDONED] unions with structs dont display properly
    union with struct overlaying with U32 & array of 2 U16
    U32 & 2 U16s show ok
    struct doesn't but all show as the same address [ as you would expect ]
    typedef union
    struct
    uint32_t PowerEnable : 1;
    uint32_t Startup : 1;
    uint32_t Fault : 1;
    uint32_t HwFault : 1;
    uint32_t Present : 1;
    uint32_t xExpanderPresent : 1;
    uint32_t xExpanderOk: 1;
    uint32_t : 1;
    uint32_t xChargerPresent : 1;
    uint32_t xChargerOk : 1;
    uint32_t SmartBattPresent : 1;
    uint32_t SmartBattOk : 1;
    uint32_t : 4;
    uint32_t HwFaultShadow : 1;
    uint32_t Updated : 1;
    uint32_t Channel : 1;
    uint32_t u32;
    uint16_t aU16[2];
    } UnBatteryStatusReg;
    Which version of Ozone are you using exactly?
    Do you see the same issue in the latest version?
  • no
    typedef union
    struct
    uint32_t SldEn : 1;
    uint32_t TecEn : 1;
    uint32_t IntegrationCap : 1;
    uint32_t : 1;
    uint32_t SaveCal : 1;
    uint32_t LoadCal : 1;
    uint32_t LoadCalToSystem: 1;
    uint32_t RebootFpga : 1;
    uint32_t StopAnMux : 8;
    uint32_t EraseFgpaFirmware1 : 8;
    uint32_t EraseFgpaFirmware2 : 8;
    uint32_t U32;
    } UnControlReg;
    you can see in the picture the bottom 2 bits are set in the U32 but you dont display any of the struct values
  • Ok now I am confused.
    I ask if the issue is in the latest version and you write no. Yet you post a reproducer.
    I assume this is not resolved yet, correct?
    We will check if the issue is reproducible and report back with our findings.
    The reported behaviour is not reproducible for me with Ozone V3.26h, see picture attached.
    Could you provide an example project for reproduction that would run on an eval board?
    An elf file + the Ozone project .jdebug file should be sufficent.
  • it's compiled under IAR
    this is a dump out of that union + another one using the iar ielfdumper tool
    0x1'a743: | + union_type (82)
    | | sibling 0x1'a7d1
    | | name UnControlReg
    | | byte_size 0x4
    0x1'a756: | | member (86)
    | | type 0x1'a76c
    | | accessibility public
    | | data_member_location [plus_uconst 0]
    0x1'a75f: | | member (49)
    | | type 0x1'a9a5
    | | name u32
    0x1'a76c: | | + structure_type (87)
    | | | sibling 0x1'a7d0
    | | | byte_size 0x4
    0x1'a772: | | | member (88)
    | | | type 0x1'a9a5
    | | | name OpenLoop
    | | | data_bit_offset 0x0
    | | | bit_size 1
    0x1'a783: | | | member (88)
    | | | type 0x1'a9a5
    | | | name SaveCal
    | | | data_bit_offset 0x1
    | | | bit_size 1
    0x1'a793: | | | member (88)
    | | | type 0x1'a9a5
    | | | name LoadCal
    | | | data_bit_offset 0x2
    | | | bit_size 1
    0x1'a7a3: | | | member (92)
    | | | type 0x1'a9a5
    | | | data_bit_offset 0x3
    | | | bit_size 1
    0x1'a7ab: | | | member (88)
    | | | type 0x1'a9a5
    | | | name EraseCal1
    | | | data_bit_offset 0x4
    | | | bit_size 8
    0x1'a7bd: | | | member (88)
    | | | type 0x1'a9a5
    | | | name EraseCal2
    | | | data_bit_offset 0xc
    | | | bit_size 8
    | | +-- 0
    | +-- 0
    0x1'1ebd: | + union_type (64)
    | | sibling 0x1'2012
    | | name UnStatusReg
    | | byte_size 0x4
    0x1'1ecf: | | member (70)
    | | type 0x1'1ee5
    0x1'1ed8: | | member (39)
    | | type 0x1'2204
    | | name u32
    0x1'1ee5: | | + structure_type (65)
    | | | sibling 0x1'2011
    | | | byte_size 0x4
    0x1'1eeb: | | | member (66)
    | | | type 0x1'2204
    | | | name ADCUpdated
    | | | data_bit_offset 0x0
    | | | bit_size 1
    0x1'1efe: | | | member (66)
    | | | type 0x1'2204
    | | | name TestMode
    | | | data_bit_offset 0x1
    | | | bit_size 1
    0x1'1f0f: | | | member (66)
    | | | type 0x1'2204
    | | | name CalDataValid
    | | | data_bit_offset 0x2
    | | | bit_size 1
    0x1'1f24: | | | member (66)
    | | | type 0x1'2204
    | | | name StartingUp
    | | | data_bit_offset 0x3
    | | | bit_size 1
    0x1'1f37: | | | member (66)
    | | | type 0x1'2204
    | | | name DoingStartUpChecks
    | | | data_bit_offset 0x4
    | | | bit_size 1
    0x1'1f52: | | | member (66)
    | | | type 0x1'2204
    | | | name BadPressureSensor
    | | | data_bit_offset 0x5
    | | | bit_size 1
    0x1'1f6c: | | | member (67)
    | | | type 0x1'2204
    | | | data_bit_offset 0x6
    | | | bit_size 2
    0x1'1f74: | | | member (66)
    | | | type 0x1'2204
    | | | name EepromFound
    | | | data_bit_offset 0x8
    | | | bit_size 1
    0x1'1f88: | | | member (66)
    | | | type 0x1'2204
    | | | name EepromOk
    | | | data_bit_offset 0x9
    | | | bit_size 1
    0x1'1f99: | | | member (66)
    | | | type 0x1'2204
    | | | name DriverFound
    | | | data_bit_offset 0xa
    | | | bit_size 1
    0x1'1fad: | | | member (66)
    | | | type 0x1'2204
    | | | name DriverOk
    | | | data_bit_offset 0xb
    | | | bit_size 1
    0x1'1fbe: | | | member (66)
    | | | type 0x1'2204
    | | | name AmbPressFound
    | | | data_bit_offset 0xc
    | | | bit_size 1
    0x1'1fd4: | | | member (66)
    | | | type 0x1'2204
    | | | name AmbPressOk
    | | | data_bit_offset 0xd
    | | | bit_size 1
    0x1'1fe7: | | | member (66)
    | | | type 0x1'2204
    | | | name OutPressFound
    | | | data_bit_offset 0xe
    | | | bit_size 1
    0x1'1ffd: | | | member (66)
    | | | type 0x1'2204
    | | | name OutPressOk
    | | | data_bit_offset 0xf
    | | | bit_size 1
    | | +-- 0
    | +-- 0
    Unfortunately this is not helping.
    We would need to reproduce the behaviour on hardware.
  • how do I know what boards you have ?
    this elf file is for a samd20J17
    it won't run on any hardware you have but you can find the "Registers" global object to find a bunch of examples of those structures
    • c.out.zip
      (385.63 kB, downloaded 252 times, last: )
    This should not matter. This is a pure software issue and should be target independent, correct?
    So if you could provide us with an reproduction project that could run on any Arm Cortex-M eval board that would be helpful.
    We have over 3500 evalboards in house so there is a good chance that we already have it. If not we will get it.
    Ok good. We have e.g. the SAM D20 Xplained Pro in house.
    We would need a project that could run on an evalboard. A simple stripped down project that shows this behaviour would be sufficient.
    Could you provide this?
    Please understand that the time we can spend on investigations is very limited which is why it is a requirement that in case of bug reports a universal reproduction setup is provided as we can't spend an undefined amount of time on trial and error without guarantee for success.
  • well just download it, find the instance of the structure and just change the U32 / memory fundamental value . that is all you need to show the issue as "Registers" is a global static variable with the union structs inside it
