[SOLVED] Jlink
  • [SOLVED] Jlink
    ERROR: Could not connect to target.
    SEGGER J-Link GDB Server V6.98a Command Line Version
    JLinkARM.dll V6.98a (DLL compiled Mar 5 2021 17:01:02)
    Command line: -nosilent -swoport 2334 -select USB=51020002 -telnetport 2335 -singlerun -endian little -noir -speed auto -port 2336 -vd -device MKE18F512xxx16 -if SWD -halt -reportuseraction
    GDBInit file: none
    GDB Server Listening port: 2336
    SWO raw output listening port: 2334
    Terminal I/O port: 2335
    Generate logfile: off
    Verify download: on
    Init regs on start: off
    Silent mode: off
    Single run mode: on
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: MKE18F512xxx16
    Target interface: SWD
    Target interface speed: auto
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Device "MKE18F512XXX16" selected.
    Firmware: J-Link V11 compiled Mar 3 2022 10:16:14
    Hardware: V11.00
    S/N: 51020002
    Feature(s): GDB
    Checking target voltage...
    Target voltage: 3.30 V
    Listening on TCP/IP port 2336
    Connecting to target...
    InitTarget() start
    InitTarget()
    Connect Under Reset
    Communication error while accessing MDM-AP.
    Connect Under Reset
    InitTarget() end
    InitTarget() start
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    InitTarget() end
    InitTarget() start
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    InitTarget() end
    InitTarget() start
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    InitTarget() end
    I suggest to check out the following article:
    wiki.segger.com/J-Link_cannot_…the_CPU#Target_connection
